Home » Sponsored » Pi Speakers » Two Tower initial impressions
Re: Hey Steve Brown, about those IC's? [message #48255 is a reply to message #48253] Sun, 20 November 2005 02:33 Go to previous messageGo to previous message
I just use the blue AR IC's you get at Best Buy. They're shielded and, I think, neutral. What else could you ask for?
Steve and I talked cables a bit yesterday and he mentioned a Gary Pimm DIY design using Litz wire. I googled for it but can't find any info.
I have the original Homegrown silver coated copper braid unshielded which are a little bright. I've built Kevin Haskins version of the Risch Belden co-ax cross connect which were just OK. I see on his site that he has finished cross connect with Cardas Litz wire for $85. The only truly outstanding cable I have experience with is the 1985 vintage Straightwire I use from phono to pre-amp. It's thin and shielded so must be a small gauge and the RCA looks like all of that era, i.e. no gold, no silver no locking or other doo-dads.
Now if you want to talk speaker cable............
Previous Topic: request for 2 pi bass reflex plans
Next Topic: Request for wooden HF horn plans
Current Time: Mon Nov 02 16:10:34 CST 2026
