Home » Sponsored » Pi Speakers » Heat Exchanger Prototypes
Re: Heat Exchanger Prototypes [message #48084 is a reply to message #48083] Sat, 29 October 2005 06:48 Go to previous messageGo to previous message
That's cool, Leland. Should work great. And the truth is, you don't want the electro-mechanical parameters to shift, so if they don't, that's great. Use the T/S measurement technique shown in the post at the link. If you don't notice much of a shift at moderate and higher power levels, all the better. Put the system together, and measure the response curve and output at high power levels and see how it works out. You should have a linear response, less parameter shift, lower compression and higher power handling, so the system will just generally be more robust.
Previous Topic: Measurement Technique for Electric Bass
Next Topic: Anyone using ribbon tweeters in place of horns?
Current Time: Thu Nov 19 10:30:27 CST 2026
