Home » Sponsored » Pi Speakers » Stage 4 Update
Forget the spades [message #48057 is a reply to message #48054] Mon, 24 October 2005 07:43 Go to previous messageGo to previous message
Spades are poor connectors. Solder the wires directly to the drivers instead. If you want the option to disconnect the drivers, then solder a 4" length of wire to the driver and connect the bare wire on the other end with electrical screw caps. Twist it in tight.
Previous Topic: Heat exchangers Wayne
Next Topic: Pic Posting
Current Time: Sun Nov 01 14:10:10 CST 2026
