Home » Sponsored » Pi Speakers » The Most Powerful Subwoofer in the World
Re: The Most Powerful Subwoofer in the World [message #47996 is a reply to message #47993] Sat, 15 October 2005 07:48 Go to previous messageGo to previous message
The reason for the response ripple is the front chamber is larger than 20 liters. Front chamber volume is actually about 30 liters on this model. I'm happy with the response that provides, but it could be made smoother if the front chamber were reduced to 20 liters. I think you recall discussions about this between you and I in the past.
I use fill to reduce the front chamber volume, and without fill, it's 40 liters. When the front chamber is 40 liters, response is similar to the LABhorn. It's fine that way, but by reducing the front chamber, the ripple is reduced. The magnet sets the limit of depth for the chamber, but volume reduction can be done by displacing some space in the front chamber using filler material or panels. It's pretty easy to get front chamber volume down to 30 liters, but going smaller than that requires more attention and difficult fill shapes.
See the comparison of response curves with various front chamber sizes:
12π basshorn subwoofer with 20 liters of front chamber volume12π basshorn subwoofer with 30 liters of front chamber volume12π basshorn subwoofer with 40 liters of front chamber volume
Previous Topic: subwoofer for my 4Pi
Next Topic: Speaker Insulation
Current Time: Tue Nov 03 01:55:50 CST 2026
