Home » Sponsored » Pi Speakers » Question About MDF and Humidity...
Re: MDF is a sponge [message #47985 is a reply to message #47978] Fri, 14 October 2005 22:17 Go to previous message
If you have not built your cabinets yet: Please consider building from plywood. MDF will change over the course of time. Sealing the inside would be a big plus since a port in the cabinet will always allow outside air to circulate. Home Depot and other home centers often have imported plywood in Birch at prices not much more than MDF. Baltic is good plywood but no need for the expense if you dont want. I used a lot of MDF in the past and have decided I made a poor choice. Think about your efforts and how long you want your projects to last.
Previous Topic: pi7 midhorn reflections.
Next Topic: * 12 Pi ? *
Current Time: Tue Nov 03 06:38:51 CST 2026
