Home » Sponsored » Pi Speakers » Question About MDF and Humidity...
Re: Question About MDF and Humidity... [message #47980 is a reply to message #47978] Fri, 14 October 2005 06:35 Go to previous messageGo to previous message
MDF is usually OK if it isn't exposed to liquid water. It may swell a very slight amount in high humidity, but it won't become weak. But if you put a veneer on it, the slight swelling is sometimes just enough to see a ridge forming under the veneer at the seam of butt joints after a period of time. This can be solved using mitered joints so that the only seam is at the corner.
Previous Topic: pi7 midhorn reflections.
Next Topic: * 12 Pi ? *
Current Time: Tue Nov 03 06:38:06 CST 2026
