Home » Sponsored » Pi Speakers » Question About MDF and Humidity...
Question About MDF and Humidity... [message #47978] Fri, 14 October 2005 03:46 Go to previous message
ArthurPrince is currently offline  ArthurPrince
I plan on building a pair of 2 Pi Towers out of MDF. My main concern is what I have read about MDF and it being succeptable to humidity. I will be painting the exterior with several coats of primer and a top coat, finished with a gloss coat. I am wondering if putting a couple coats of primer on the inside walls of the speakers might help make them less affected by humidity? The idea being that the paint and primer would seal the MDF from surrounding conditions. Would this work or would it make little difference? Also, would primering the inside walls have any effect on sound? Thanks for any input.
Previous Topic: pi7 midhorn reflections.
Next Topic: * 12 Pi ? *
Current Time: Tue Nov 03 10:21:11 CST 2026
