Home » Sponsored » Pi Speakers » pi7 midhorn reflections.
Horn suggestion. [message #47975 is a reply to message #47968] Thu, 13 October 2005 23:18 Go to previous messageGo to previous message
Kim Schultz is currently offline  Kim Schultz
Ahh....
My fault, I was thinking fullrange again
This is only used as a midrange horn, so your right, it doesn´t matter.
A while back you said the Peavey CH-3 horn was one of your favorites.
Do you think this horn is better sounding than the H-290 ?
I found a horn that looks very much like the CH-3.
It´s a Monacor MRH-120.
http://www.paso.co.uk/store/en/view_product/2/555/?product_view=more_info
http://www.bmm-electronics.nl/Product.asp?Product_ID=2618
I ask because the company where I got the PSD-2002 sent me the screw on type, instead of the bolt on type, and it would be easier to use them on these horns, and then ordering some new for the H-290 I have now.
Regards
Kim
Previous Topic: ** Pi chart request **
Next Topic: Question About MDF and Humidity...
Current Time: Tue Nov 03 07:53:10 CST 2026
