Home » Sponsored » Pi Speakers » *7 pi version
Re: *7 pi version [message #47957 is a reply to message #47952] Tue, 11 October 2005 22:08 Go to previous message
I suggest using the two π towers with their backs against a rear wall, spaced 3" - 6" away from it. If they need to be placed near corners, position them a couple feet away from the corners if you can.
If you're interested in making a π cornerhorn, the Alpha 10 makes an excellent driver for a five π model. Make it similarly to seven π cabinets, with the same midhorn, tweeter and crossover. The bass bin should be 4.5ft3 tuned to 30Hz and you can use the same porting as the tower two π cabinet. Put the woofer a little lower than central and place the port between it and the floor. You can confirm this placement with Martin King's spreadsheet to identify standing wave modes, if you wish.
Previous Topic: Two Pi Towers - Placement?
Next Topic: rajeev cooling *
Current Time: Sun Nov 01 14:22:16 CST 2026
