Home » Sponsored » Pi Speakers » Mid-Horn Dimensions
Re: Mid-Horn Dimensions [message #47909 is a reply to message #47905] Fri, 07 October 2005 19:42 Go to previous messageGo to previous message
Ok, so keeping the flare angle and final area teh same as the original design (this is for the mid-horn on the pi-7, btw) is important, but I may loose some pattern control with the narrower horizontal dimension. Is that correct? Hmmm...its all about compromises, isn't it? There is no free ride.
So if I've got this right, I would probably loose some stereo imaging with a square horn rather than a rectangular horn.
Previous Topic: Listening results with Theater 4 variation
Next Topic: stands
Current Time: Fri Oct 02 14:28:44 CDT 2026
