Home » Sponsored » Pi Speakers » Listening results with Theater 4 variation
Re: Listening results with Theater 4 variation [message #47902 is a reply to message #47900] Fri, 07 October 2005 08:36 Go to previous messageGo to previous message
Lebob is currently offline  Lebob
Thanks for the detailed response. I am going to get my speaker books out and do some reading. These are the best speakers with my 45 amp to date.
I guess my question should have been more specific. Would raising the the tuning frequency a bit strengthen the mid-bass? If yes, to what extent can I raise the tuning of the boxes to taste with out messing things up? I made two thick paper ports to lengthen the Theatre 4 ports an inch and another two inches from your design's 3.5 inch length. Both seemed to strengthen the lower midbass a bit with some loss of the lowest bass. The percieved midrange was also affected, not sure if it was better or worse.
Thanks,
Orren
Previous Topic: ** 7 or 8 Pi **
Next Topic: Mid-Horn Dimensions
Current Time: Thu Nov 19 12:33:30 CST 2026
