Home » Sponsored » Pi Speakers » Horn lens and SPL
Re: Horn lens and SPL [message #47796 is a reply to message #47795] Sun, 25 September 2005 23:13 Go to previous messageGo to previous message
There are a few things that determine on-axis SPL from a horn. One is the conversion efficiency of the driver, itself. Another is the amount of loading from the horn, how effectively it is matched with the driver and how well it matches the driver's acoustic impedance with that of the environment. And the other is the radiating angle, how much sound is focused or spread out.
A horn has changing directivity with respect to frequency, so that's an important consideration too. If directivity narrows considerably at high frequencies, then on-axis SPL will rise at high frequency because HF energy is more tightly focused. But off-axis tonal balance will be non-uniform as a result.
You can model a horn with a program like Hornresp to get an idea of its performance. It also has a feature that will allow you to include directivity in your model. It assumes the diaphragm moves as a rigid piston, so it cannot include the additional response generated by the driver when the cone enters breakup modes. But it is a very useful modeling tool, nonetheless.
Previous Topic: Two π Tower Plans request
Next Topic: Subs from Alpha 10 drivers
Current Time: Mon Nov 16 10:35:08 CST 2026
