Home » Sponsored » Pi Speakers » Dayton Speaker Cabinets
Re:Not plywood [message #47783 is a reply to message #47782] Sat, 24 September 2005 04:34 Go to previous messageGo to previous message
Meant for table tops and shelves. Narrow pieces glued up into wider widths, not really laminations as we think of them in plywood. Should limit seasonal movement and they are quite flat and have nice straight edges.
Some 12's, some 18's (widths), 6d finish nails and carpenters glue would be all you need to build boxes.
At my Home Depot or Lowe's the panel saw is off square and they use the tape attached to the frame to size your cut. That leaves you to square the pieces during glue-up and trim the edges that protrude. And that requires a sharp plane or router which defeats the purpose of working w/o buying more tools.
Previous Topic: New info about the Prosound Shootout
Next Topic: Two π Tower Plans request
Current Time: Sun Nov 01 15:16:05 CST 2026
