Home » Sponsored » Pi Speakers » No more sandboxes, no more 45 degrees
Re: No more sandboxes, no more 45 degrees [message #47747 is a reply to message #47746] Tue, 20 September 2005 05:04 Go to previous messageGo to previous message
spkrman57
Sounds like the "near-field" listening postion works well for you. I myself would love to have a large room to work with(only if I win the lotto).
I am also using a 1st order crossover on my horns, Yamamoto 45 SET provides 2 wpc so is fairly safe. My JBL is a E130 reconed with 2225 cone kit. I used a 1.2 mh coil in series. I paralleled 3 caps for the HF horn section(2 ufd oil/12 ufd MPT/.68 ufd MPP)into a 8 ohm L-pad.
One other point, in the short range, nothing beams like a round horn. However as I showed Bill, the secret is to be off axis with them and imaging comes through in spades.
Downfall on that is only 1 person sits in the "sweet-spot"!
Thanks for the kind words Bill!
Ron
Previous Topic: Stage 4's
Next Topic: sub plans
Current Time: Sun Oct 04 04:21:36 CDT 2026
