Home » Sponsored » Pi Speakers » 12 π basshorn - Coming together - Part 1
Re: 12 π basshorn - Coming together - Part 2 [message #47740 is a reply to message #47431] Sun, 18 September 2005 11:31 Go to previous messageGo to previous message
Now we build up the horn flare from the motor chamber outward. First, glue the throat panel brace in place. You might want to drill shallow holes and use a short 1/2" dowel section as a positioning pin.
http://www.pispeakers.com/Basshorn/Throat_Panel_Brace.jpg
Motor chamber and throat panel brace
Attach the throat panel and the upper braces.
http://www.pispeakers.com/Basshorn/Throat_Expansion_And_Braces.jpg
Throat expansion and braces
Attach the top and nose pieces. Both sides are attached to make sure fit is good. One side is glued and permanently attached, but the other side is only temporarily screwed in place.
http://www.pispeakers.com/Basshorn/Throat_Panel_and_Top.jpg
Throat panel and top
http://www.pispeakers.com/Basshorn/Rear_View_Motor_Chamber_Sides_and_Top.jpg
Rear view of motor chamber with sides and top attached
Prepare the back panel by cutting the connector panel hole and applying the finish coat. You won't want to paint after the panel is in place, so do it ahead of time. After it is dry, you can attach the back panel and connect the internal wiring. Notice the braces between motor chamber and back panel. Having the side mounted lets you check fit. This photo was taken after the back was already mounted and the side removed for easier access to horn internals.
http://www.pispeakers.com/Basshorn/Internal_Wiring.jpg
Internal wiring
Similarly, the angled pieces in back must have their finish coat applied in advance. The top piece mounts a handle and the bottom piece mounts castor wheels. Notice the holes drilled for the castor wheels in the picture below.
http://www.pispeakers.com/Basshorn/Back_and_Bottom.jpg
Back and Bottom
Cut holes and insert T-Nuts to mount the handle. Here we've test fit the handle before removing it again to provide the finish coat.
http://www.pispeakers.com/Basshorn/Back_and_Top.jpg
Back and top
http://www.pispeakers.com/Basshorn/Back_and_Side.jpg
Back and side
http://www.pispeakers.com/Basshorn/Face_Down.jpg
Face down
Attach braces for the diagonal pieces, both top and bottom. The bottom ones should be placed immediately above the castor wheels, to provide strength in this area. The braces on the top panel should be placed near the handle mounts to provide extra strength too. Mount the wheels and handle.
http://www.pispeakers.com/Basshorn/Bottom_Corner_Brace.jpg
Bottom corner braces
http://www.pispeakers.com/Basshorn/Top_Corner_Brace.jpg
Top corner braces
Add the braces for the mouth area, and then attach the side. Glue them in place and the horn is finished, ready for painting.
http://www.pispeakers.com/Basshorn/Unfinished_Front_View.jpg
Front view, before paint
http://www.pispeakers.com/Basshorn/Unfinished_Side_View.jpg
Side view, before paint
Previous Topic: horn design*
Next Topic: Building 2 Pi Towers - Any Experience?
Current Time: Sun Oct 18 10:23:18 CDT 2026
