Home » Sponsored » Pi Speakers » The 2 Pi Towers have me thinking about direct radiators
Re: The 2 Pi Towers have me thinking about direct radiators [message #47730 is a reply to message #47727] Wed, 14 September 2005 01:22 Go to previous messageGo to previous message
Crossover at decades is sort of a pseudo-ideal. It isn't necessarily better or anything, it's just that if you made a three-way speaker crossed at decades [20-200, 200-2000 and 2000-20,000], each subsystem would be covering exactly a 10x frequency range (a little over three octaves each) and the entire audio band would be covered.
About the Vifa DX25, I think it sounds very nice in hifi speakers designed for use under 115dB SPL. It has a wide surround and can handle some excursion, so it can be safely crossed over pretty low for a 1" dome tweeter. That characteristic also makes it respond well to first-order networks. Its response curve is ruler flat and goes waaaaay up there on the top end. So it is perfect for a studio monitor type speaker. The three π is really best suited to be a studio monitor, similar to a Studio two π with premium components. It sounds very nice.
Compression horns have other advantages. They're horns, so you can set directivity. They're efficient, so you can use them in powerful speakers that get loud. Those are very attractive features too, and important in many designs. I use them in a lot of my systems.
Previous Topic: two pi studio
Next Topic: Wayne ..Thanks
Current Time: Mon Nov 02 11:06:39 CST 2026
