Home » Sponsored » Pi Speakers » Audiophile Series seven π
| SUMMARY 2 [message #47655 is a reply to message #47652] |
Sat, 03 September 2005 08:49   |
beto1
Messages: 36 Registered: May 2009
Baron |
Hi, so, depends on my budget, the final solution will be the four pro model, first, or the four stage. Then, when I can get the corner situation, upgrading to the seven pi model. On both, with Eminence compression driver. But, as I have read, also the Altec 802 or 902 will be a perfect match (like Bill speakers). Maybe I can get some good pair here. One though comes to my mind: can I build the four model, but with the mid woofer and the tweeter and on a diferent cabinet the Eminence Magnum 15 or 18, all in bass reflex arrange? Does anyone do this design? Just though. Also, I wonder if there is some more detailed plans (construct details)? Thanks a lot, Beto
By: beto1 on Wed, 24 August 2005 17:13
Re: Hola Beto; Hey Guys, Beto's in Chile and needs a lttle help
Gracias Bill!!
By: beto1 on Wed, 24 August 2005 21:16
Re: Audiophile Series seven π
By: beto1 on Wed, 24 August 2005 21:08
You've got mail!
Eminence or JBL
By: beto1 on Fri, 26 August 2005 21:03
Re: Eminence or JBL
Re: Eminence or JBL
By: beto1 on Sat, 27 August 2005 18:45
Re: Eminence or JBL
Re: Eminence or JBL
By: beto1 on Sat, 27 August 2005 20:35
Re: Eminence or JBL
Re: Eminence or JBL
By: beto1 on Sun, 28 August 2005 20:06
Re: Eminence or JBL
CORNER SITUATION
By: beto1 on Mon, 29 August 2005 06:27
Re: CORNER SITUATION
By: beto1 on Tue, 30 August 2005 10:00
4 π upgrading to 7π
By: beto1 on Tue, 30 August 2005 20:04
Re: 4 π upgrading to 7π
By: beto1 on Wed, 31 August 2005 11:45
JBL & LOW POWER SET
By: beto1 on Thu, 01 September 2005 11:46
Re: JBL & LOW POWER SET
THANK YOU , WAYNE!!!
By: beto1 on Fri, 02 September 2005 11:32
Re: THANK YOU , WAYNE!!!
SUMMARY 2
By: beto1 on Sat, 03 September 2005 08:49
Re: SUMMARY 2
JBL & amp design
By: beto1 on Thu, 01 September 2005 13:25
Re: JBL & amp design
Current Time: Sat Nov 07 02:53:56 CST 2026
