Home » Sponsored » Pi Speakers » Audiophile Series seven π
Re: JBL & LOW POWER SET [message #47641 is a reply to message #47637] Thu, 01 September 2005 16:11 Go to previous messageGo to previous message
Ken's speakers use the JBL 2227, which has more rising response than the 2226. Also, the Audio Note amps are full in the bass, so you'll find it a very good combination. I'd suggest the 2226 if you can afford it. The Omega 15 is a good choice too, at about 1/3rd the cost. The Magnum 15HO is probably the best for performance/dollars, but only if you can run it as a three-way.
Previous Topic: Ping: ColinHester
Next Topic: Anyone have comments on the Stage four Pi or pictures of finished Pi's
Current Time: Sat Nov 07 02:53:45 CST 2026
