Home » Sponsored » Pi Speakers » Audiophile Series seven π
| Re: CORNER SITUATION [message #47614 is a reply to message #47610] |
Mon, 29 August 2005 23:59   |
If it isn't in the corner, several things happen. None of them are terrible, but none are really good either. The corner forces all sound to radiate into the room from the apex. It limits the radiating angle to 90º, and this increases the intensity of sound. It also prevents sound from reflecting off the back or side walls, because that is their launch point. Sound travels along them or out into the room rather than bouncing off them, so early reflections are reduced. The midrange and tweeter horns are also 90º horns, so their pattern remains within the wall angle too, again, reducing early reflections. If you move the speaker so that it is no longer in the corner pointing into the room, you lose some or all of these benefits.
By: beto1 on Wed, 24 August 2005 17:13
Re: Hola Beto; Hey Guys, Beto's in Chile and needs a lttle help
Gracias Bill!!
By: beto1 on Wed, 24 August 2005 21:16
Re: Audiophile Series seven π
By: beto1 on Wed, 24 August 2005 21:08
You've got mail!
Eminence or JBL
By: beto1 on Fri, 26 August 2005 21:03
Re: Eminence or JBL
Re: Eminence or JBL
By: beto1 on Sat, 27 August 2005 18:45
Re: Eminence or JBL
Re: Eminence or JBL
By: beto1 on Sat, 27 August 2005 20:35
Re: Eminence or JBL
Re: Eminence or JBL
By: beto1 on Sun, 28 August 2005 20:06
Re: Eminence or JBL
CORNER SITUATION
By: beto1 on Mon, 29 August 2005 06:27
By: beto1 on Tue, 30 August 2005 10:00
4 π upgrading to 7π
By: beto1 on Tue, 30 August 2005 20:04
Re: 4 π upgrading to 7π
By: beto1 on Wed, 31 August 2005 11:45
JBL & LOW POWER SET
By: beto1 on Thu, 01 September 2005 11:46
Re: JBL & LOW POWER SET
THANK YOU , WAYNE!!!
By: beto1 on Fri, 02 September 2005 11:32
Re: THANK YOU , WAYNE!!!
SUMMARY 2
By: beto1 on Sat, 03 September 2005 08:49
Re: SUMMARY 2
JBL & amp design
By: beto1 on Thu, 01 September 2005 13:25
Re: JBL & amp design
Current Time: Sat Nov 07 02:54:08 CST 2026
