Home » Sponsored » Pi Speakers » tuning the Alpha 10"
Re: tuning the Alpha 10" [message #47486 is a reply to message #47485] Tue, 16 August 2005 10:32 Go to previous messageGo to previous message
If I remember, the Oris horn can be used down to around 250Hz. If you crossover there, wavelegth is about 4½ feet long. I'd probably use a simple first-order filter, just a 6.0mH coil in series with the woofer. You can expect summing to be good if the woofer is placed directly underneath the Oris horn.
Previous Topic: What if the "live cabinet" Co's. like Audio Note are right?
Next Topic: Speaker Voice Coil Cooling System Valve
Current Time: Sat Oct 17 10:47:29 CDT 2026
