Home » Sponsored » Pi Speakers » Amp selection for 2 Pi Towers.
Re: Amp selection for 2 Pi Towers. [message #47461 is a reply to message #47460] Wed, 10 August 2005 21:27 Go to previous message
I can understand your concern, but I think it's unfounded. Vacuum tubes are no more fragile than light bulbs. Remember that America went to the moon at a time when vacuum tubes were in everything. Without commenting on quality or any of the tube-verses-transistor debates, I'd say that you shouldn't worry about the fragility of a tube amp. It's just not an issue.
Transformers rarely fail, and so that's not really all that much of a concern. Some tubes are expensive, but most tube amps under a few grand use tubes that aren't that expensive. UPS can damage transistor amps just as easily as they can damage tube amps. They're usually pretty good, but I've seen 'em knock stuff so hard that metal chassis parts have bent.
Previous Topic: Pi 4 Theater with Coral H30 Horn Tweeter 3-20kHz 94dB/W-m
Next Topic: Big Amp mating with a 4 Pi
Current Time: Sun Oct 25 06:34:51 CDT 2026
