Home » Sponsored » Pi Speakers » Suggestions for Active crossover for Theater 4 pi (long)
Re: Suggestions for Active crossover for Theater 4 pi (long) [message #47427 is a reply to message #47426] Wed, 03 August 2005 14:13 Go to previous messageGo to previous message
I don't have the particular setup you have, but I built a sub with
one of the plate amps from Parts Express. Its the 250W, no remote
one. Its driven from the HT receiver sub out, so no external XO.
The plate amp does have line level stereo in/out, so you can put
it in the signal path. I don't use it that way so I don't know
if that's better or worse than using a Y connector on your preamp
outputs. The other thing to think about is that if you put the plate
amp in the middle, I have no idea how good (slope, etc.) the return
feed is or if the XO freq tracks the knob or not. I'd go for an
external XO and the plate amp.
I like to brag: http://cerchaos.homeip.net:1280/woodworking5.html
Chris
Previous Topic: 12 π basshorn - just about ready for prime time
Next Topic: Pi 4 Theater with Coral H30 Horn Tweeter 3-20kHz 94dB/W-m
Current Time: Thu Oct 22 21:26:02 CDT 2026
