Home » Sponsored » Pi Speakers » Active xover's
Re: Active xover's [message #47410 is a reply to message #47408] Thu, 28 July 2005 14:19 Go to previous message
GrantMarshall is currently offline  GrantMarshall
Thanks for the response Larry.
I understand it now I think. With freqency division only a certain range makes it to the amp. If you mixed 4 and 8 ohms one amp would work harder as a result of it. As long as you use integrated amps you can adjust.
Thanks again.
Grant.
Previous Topic: LT250 Horn Flare?
Next Topic: Hornsub shootout
Current Time: Sun Nov 15 09:53:35 CST 2026
