Home » Sponsored » Pi Speakers » 2 Pi tower baffles
Re: If your doing something kinda fancy... [message #47396 is a reply to message #47383] Mon, 25 July 2005 14:44 Go to previous messageGo to previous message
Shane,
Don't let the higher cost of BB over MDF scare you. If you get some BB that's nicely surfaced (no footballs) and work carefully with it, there's no need for veneer. I figure you'll need at least 30 sq ft of veneer plus 20% waste to cover the Towers and that can cost you about $100. Sometimes, it's worth paying extra for the BB to avoid the cost of veneer. You'll just have to think of a creative way to work with the edging, either hiding it or incorporating it into your design. Also, I find the birch can do a passable imitation of cherry if finished properly.
Previous Topic: Reflex volume of 4PI Pro - about 2.5 ft^3 ?
Next Topic: Plans For 1 PI
Current Time: Sun Nov 15 09:37:31 CST 2026
