Home » Sponsored » Pi Speakers » LT250 Horn Flare?
Re: LT250 Horn Flare? [message #47370 is a reply to message #47369] Sat, 23 July 2005 00:45 Go to previous messageGo to previous message
Personally, I don't like narrow dispersion horns for home hifi. It just doesn't sound as natural as sound coming from a wider flare does, especially 90º horns coming from the room's corner. But the LT250 is a pretty good horn and doesn't sound colored when used with appropriate compensation, so if space is tight, that will work pretty well for you. I just prefer a 90º horn.
Previous Topic: Plans For 1 PI
Next Topic: Active xover's
Current Time: Mon Nov 09 18:40:12 CST 2026
