Home » Sponsored » Pi Speakers » Wayne, Does the TAD TD-4001 need top octave compensation?
Re: Wayne, Does the TAD TD-4001 need top octave compensation? [message #47309 is a reply to message #47308] Thu, 14 July 2005 11:31 Go to previous messageGo to previous message
Compression driver EQ depends on the horn chosen. The driver itself is the culprit, but the horn may provide some acoustic equalization via collapsing DI. The thing to look at is plane wave tube response.
I've used the TAD 4001, and found that it does benefit from top octave compensation, but not as much as the JBL 2446. Some people use the TAD 4001 on horns that provide enough EQ acoustically, but this means that polar response suffers. For stereo HiFi use, I prefer to use horns that have collapsing DI in the vertical and a constant 90° coverage angle in the horizontal axis. This provides a good compromise solution, requiring less electrical EQ and making compensation fairly simple.
Previous Topic: Thermionic plans
Next Topic: possibly silly question
Current Time: Thu Nov 12 11:23:43 CST 2026
