Home » Sponsored » Pi Speakers » Speaker Voice Coil Cooling System Valve
Re: Speaker Voice Coil Cooling System - Heat Sink [message #47258 is a reply to message #47254] Sun, 03 July 2005 00:08 Go to previous messageGo to previous message
You could build it out of copper instead of aluminum if you wanted to do that. Either is better than none.
The pole piece of a loudspeaker pushed to its limits gets very hot. The air rushing back and forth in the vent is not heated much at all, but the magnet gets hotter and hotter, with the center pole and front pole piece getting the hottest. The air inside the cabinet can become hot, in which case the air surrounding the voice coil is hot too. So the idea is to transfer the heat into some kind of heat exchanger and get it out of the box.
Previous Topic: tuning the Alpha 10"
Next Topic: A few pics to share
Current Time: Sat Oct 17 12:04:18 CDT 2026
