Home » Sponsored » Pi Speakers » HF Compression driver without horn flare?
Re: Pipe modes [message #47179 is a reply to message #47178] Thu, 23 June 2005 07:48 Go to previous messageGo to previous message
Greggo is currently offline  Greggo
Yes, makes sense, I thought the TAD driver in question had some kind of throat as part of the assembly thus creating the potential for resonance if not directed into a horn. Not sure if that makes sense either, I just assumed from the earlier post that there was something about the physical housing of the driver that would create problems if run without a horn attached... I would love to try a TAD driver in a DIY project someday, but will probably start with a JBL from you when I am ready. Threads like these just open my mind up to different experiment and design possibilities outside of the box, always good to at least think outside the box now and then.
Greg Jensen
Previous Topic: 2206
Next Topic: Pro 3 Pi
Current Time: Thu Nov 19 15:09:49 CST 2026
