Home » Sponsored » Pi Speakers » 4Pi -> 7Pi Plan, making the 7Pi's shorter
Re: 4Pi -> 7Pi Plan, making the 7Pi's shorter [message #47143 is a reply to message #47142] Fri, 17 June 2005 00:32 Go to previous messageGo to previous message
One possibility is to make your four π cabinets with the tweeter external, and moving the woofer up in the cabinet. That way you can add the midhorn and change crossover later. It's best to put the system in the corner, facing 45º, just like the cornerhorn. That will give you a better wave launch, a better reverberent field and better response through the bass and midrange. But you can also place them with their backs against a wall, if corners aren't available.
Previous Topic: Box and port size for eminence magnum 12ho
Next Topic: Peizo tweeter use help
Current Time: Sat Nov 07 14:45:53 CST 2026
