Home » Sponsored » Pi Speakers » How do you lift your PI?
Re: How do you lift your PI? [message #47085 is a reply to message #47074] Tue, 07 June 2005 11:24 Go to previous messageGo to previous message
GarlandGarland is currently offline  GarlandGarland
In my room, I actually got the soundstage from a pair of Studio 2 Pi's to lift up considerably just by tipping them back about an inch and a half in the front. Still not ideal but the bass is enhanced with the low placement. My Theater 4's sound best tipped back some as well but the height of the image remains the same either way.
I'd try making simple four-sided risers from as heavy a plywood as you can find; maybe 2 layers of 3/4"BB. Cinderblocks may be a cheap way to experiment with height; Home Despot sells various sizes.
G.
Previous Topic: Studio Two tweak - Wow!
Next Topic: Speaker Suggestions
Current Time: Sun Nov 15 07:34:55 CST 2026
