Home » Sponsored » Pi Speakers » Will bi-amping work like this?
Re: Will bi-amping work like this? [message #47064 is a reply to message #47047] Sat, 04 June 2005 20:57 Go to previous messageGo to previous message
Bill, if you're using two different amps, they most likely will have different gain. You'll need a way to adjust the input levels for each amp so the hi and low will match again. A simple pot in place of the input resistor will do.
If your HF passive XO has a straight-forward L-pad for attenuation (no HF compensation network), then take it out and attenuation at the HF amp's input. No sense dumping power into the tweeter only to be eaten up by the L-Pad.
gar.
Previous Topic: pi stagea 4 construction
Next Topic: Tweeter horn question again...
Current Time: Sun Nov 22 11:27:47 CST 2026
