Home » Sponsored » Pi Speakers » Finished with S.E.X., what's next?
I drive Theater 4 Pi's with my Paramours... [message #47035 is a reply to message #47028] Fri, 03 June 2005 11:18 Go to previous messageGo to previous message
GarlandGarland is currently offline  GarlandGarland
...and highly recommend them for jazz, vocal, smaller scale rock and classical. Even with their +/- 100dB efficiency they aren't the best for larger scale rock and classical. You'd probably want more power for those. The 2 Pi's that I made for a friend are great as well, though a bit less efficient. The lack of a complicated crossover really helps here and makes these speakers a great combo with lower powered tube amps. The sound is different from the Theater 4's but very dynamic and just plain fun to listen to. May be better for rock since it doesn't try to go as low in the bass; making for a more punchy sound. Of course, all this is very personal and system/room dependent. My room is small at 11.5'x17.5'x 7.5'high.
Good luck!
Garland
Previous Topic: JBL 2226H 2 - way design for a beginner?
Next Topic: pro four Pi plans please
Current Time: Mon Nov 02 10:03:00 CST 2026
