Home » Sponsored » Pi Speakers » Should I build Pi's?
Re: Wayne, can I have the 4Pi Pro and old 7Pi Pro plans? [message #47026 is a reply to message #47006] Thu, 02 June 2005 18:53 Go to previous messageGo to previous message
Great, you will love the drivers. i have only used them on my A7s, both with their 511b horn ( and 500 hz crossover, which is probably a little low for best results) as well as the H290 I believe it is that is used on the 4Pi. Ask wayne for the plans to the 7Pi that is 3 way, but doesnot use the mid horn, but mounts it on the front baffel. It would be the same height as the 2 way version.
Enjoy,
Russellc
Previous Topic: Here's a 15" wooferer with great specs for $172
Next Topic: Pi 7's , will they work for me?
Current Time: Fri Sep 25 19:15:36 CDT 2026
