Home » Sponsored » Pi Speakers » Pi 7's , will they work for me?
Re: Pi 7's , will they work for me? [message #47025 is a reply to message #47023] Thu, 02 June 2005 18:14 Go to previous messageGo to previous message
GrantMarshall is currently offline  GrantMarshall
Hi Dave.
I have mine in a 13' 4" by 23 room and they work great. The way you describe your room you have similar space to fill.
People with 12 by 14 rooms are deciding to try these. They are too loud for my taste with the smaller room. I know, just turn it down. The thing is they don't sound "right" until they use a little bit of juice. To give you some idea of how little they take I bought an old Luxman amp with l.e.d. power meters starting at .8 watts. I have to "turn it up" to find out the meters work.
I went to Lima Ohio and saw some Edgar horns and many other high efficiency offerings. The high efficiency all have that great knock you over with a bass wave, fill your house sound.
No regrets with the Pi's though. You're looking at some nice speakers here.
Grant.
Previous Topic: Should I build Pi's?
Next Topic: DI matched two-way
Current Time: Mon Nov 02 15:04:21 CST 2026
