Home » Sponsored » Pi Speakers » Should I build Pi's?
Re: Wayne, can I have the 4Pi Pro and old 7Pi Pro plans? [message #47004 is a reply to message #46998] Wed, 01 June 2005 18:19 Go to previous messageGo to previous message
It depends. If you are getting the same drivers I did, they were OEM Jbl 2425h, so are plain fronts with a screw on mount only, no nose piece.
for all but screw on horns, you would need the adapter. I got mine from Bill when I ordered the drivers. I think parts express also has these cheap. I bought the basic plastic eminence horn that wayne sells for most of the kits, and it is a fine piece, but must be crossed over much higher than the 511b or 811b altec horns, for example. Of course to be fair, not only are most of the Pi speakers crossed over this high by design, but it is physically much smaller and compact compared to the mentioned altecs.
Russellc
Previous Topic: Here's a 15" wooferer with great specs for $172
Next Topic: Pi 7's , will they work for me?
Current Time: Fri Sep 25 19:14:38 CDT 2026
