Home » Sponsored » Pi Speakers » Should I build Pi's?
Re: Yes, I'd love to hear some [message #46980 is a reply to message #46979] Mon, 30 May 2005 03:29 Go to previous messageGo to previous message
With your budget and size constraints build the 4Pi Pro with JBL woofers and Eminence PSD-2002 horns. Just let the horns sit on top oif the cabinet. That way you have the flexibility to add the mid-horn down the road.
Don't worry about the mid-horns. The first time you listen to the 4Pros with a good SET amp you will be blown away!
Previous Topic: Here's a 15" wooferer with great specs for $172
Next Topic: Pi 7's , will they work for me?
Current Time: Mon Nov 02 17:53:01 CST 2026
