Home » Sponsored » Pi Speakers » Here we go again with another of my "What if" scenarios!
I use something like that for DJ tops [message #46953 is a reply to message #46945] Tue, 24 May 2005 08:52 Go to previous messageGo to previous message
JLapaire is currently offline  JLapaire
Delta 10 and PSD2002 on a H290 horn in a box just about large enough to fit them. They're sealed and I HP them at 200hz. Crossover is the stock Pi 1k6 with I think 10dB padding.
I modelled the Delta 10 in WinISD for the only failure I've gotten with that program. Driver specs must be off or something because the modelled curve and the RTA missed by over an octave in both sealed and ported configs. I wanted to use them 2-way in the Pi Suudio 2 boxes but no amount of tuning would produce acceptable bass. So I use them where they work best. If I had more room I'd try Wayne's midrange horns, and might anyway.
John
Previous Topic: Front loaded horn
Next Topic: Wayne, 8 pi plans
Current Time: Sun Oct 25 05:55:02 CDT 2026
