Home » Sponsored » Pi Speakers » Here we go again with another of my "What if" scenarios!
Re: Here we go again with another of my "What if" scenarios! [message #46948 is a reply to message #46947] Sun, 22 May 2005 13:57 Go to previous messageGo to previous message
You'll definitely want to attenuate the tweeter. That's easy enough. As for the rest of the circuit, I expect a single coil will work well on the Delta 10, but I'd confirm it just to be sure. You'll have mechanical crossover slopes of both the midwoofer and tweeter to consider when doing phase calculations. Might be easier these days to check response in the crossover region with Speaker Workshop or something. It's a whole lot easier than calculating everything manually. I've done the math several times, and always tried to find solutions that had some wiggle room. Makes for a lot of calculations though, that's for sure.
Previous Topic: Front loaded horn
Next Topic: Wayne, 8 pi plans
Current Time: Sun Oct 25 05:54:55 CDT 2026
