Home » Sponsored » Pi Speakers » OK Till E
Re: As one who shleps a lot of drywall............ [message #46942 is a reply to message #46940] Sun, 22 May 2005 06:28 Go to previous messageGo to previous message
Contractors come in and want us to get a forklift to load maybe 30 sheets of 4x8x1/2" drywall. But it has to be hand-loaded into their pick-up truck anyway so we just throw 15 "lifts" on a cart in about 60 seconds as they stand by amazed and then wheel it out.
Now 5/8" is a different story. That stupid 1/8" makes it 'twice' as heavy.Glue it to the studs and you really have a strong structure. Yup, drywall should be glued to the studs which eliminates a lot of fasteners so taping is quicker but also the glue keeps the board from getting concave where the framing isn't quite perfect.
If you wanted to make a really non-resonant 'wing' to substitute for a corner I would suggest 5/8" board glued to a 2x4 frame with 30# roofing felt glued to the back of the board between the studs.
Previous Topic: Eminence ASD 1001
Next Topic: pi 2 new tweeter upgrade help
Current Time: Sun Nov 01 01:40:54 CST 2026
