Home » Sponsored » Pi Speakers » Another pi midhorn question.
Another pi midhorn question. [message #46839] Sat, 07 May 2005 02:56 Go to previous message
Kim Schultz is currently offline  Kim Schultz
index.php?t=getfile&id=1473&private=0
Hi Wayne.
I wanted to make a cad drawing of the midhorn, to get the angles on the sides.
Just bought a new tablesaw, and want to try to minimize the sanding a bit, by cutting the angles on the saw.
But when I make the sides 14.5" long, the top and bottom becomes 11.37" long. And when I make the top and bottom 11" long, the sides become 14.21" long.
Which one is correct, can you tell me the exact depth of the horn, that way I can draw it up using depth instead.
I have included a picture of the two drawings.
Regards
Kim
  • Attachment: 7pi_horn.jpg
    (Size: 51.23KB, Downloaded 6411 times)
Previous Topic: 7Pi placement in my room
Next Topic: Pink Noise Vs. sweeps for measurements
Current Time: Thu Nov 05 00:48:36 CST 2026
