Home » Sponsored » Pi Speakers » Alpha drivers and more (long)
Re: Save some trouble....(unabashed plug) [message #46830 is a reply to message #46828] Fri, 06 May 2005 13:30 Go to previous messageGo to previous message
I'm real fond of the little one π and two π speakers too. And with the addition of the soft dome tweeter, they're startlingly accurate speakers. Give 'em a try, the price is dirt cheap.
You mentioned building dipoles, and the large Alphas - the 12 and 15 - have such high Q that they do pretty well on open baffles. Being a dipole, the bass will have dual lobe directionality and then up high, the circular radiator will start to have collapsing DI so you can match directivity with the horn. With the right baffle size, you could probably do a pretty good job of making DI fairly uniform throughout the band this way, with of course the exception of the rear dipole lobe.
For additional specs, contact Tom James, Jerry McNutt, or Scott Diehl over at Eminence. Being a circular radiator, the polars are fairly predictable. As for nonlinear specs, not many manufacturers are publishing nonlinear parameters yet, but Eminence has a Klippel system, so they can probably provide a dataset of nonlinear parameters for you.
Previous Topic: Which kit has the highest musical fidelity. Studio 2 or tower 2?..nt
Next Topic: Horn Damping Resistor
Current Time: Sun Nov 01 03:59:02 CST 2026
