Home » Sponsored » Pi Speakers » I went back to the "right x-over" and lost something
Re: I went back to the "right x-over" and lost something [message #46684 is a reply to message #46681] Sun, 10 April 2005 08:22 Go to previous messageGo to previous message
spkrman57
Bill,
Don't forget that you are still using a 16 ohm 2226. Therefore most likely you are still a few db shy of what the 8 ohm 2226 would give you. Also, i am using 14db attenuation on mine.
I am ready to install my JBL E-130's reconed to 2225's which are slightly more efficient than the 2226, but mostly in the midrange area above 80hz. They might be around 98.4 db/watt per the LH forum gurus. The extra efficiency is due to the E-130 magnet structure which is more powerful than the stock 2225 magnetic structure.
I am looking forward to incorporating my JBL 2242 sub to take care of any "BASS" duties! This is one "Bad-ass" driver (18")and I have a 1000 watt plate amp with adjustable EQ. I figure to use it up to maybe 60hz to 80hz. Hmmmmm wonder why "pipe organ" music is coming to mind.......
Ron
Previous Topic: zobel network..many doubts!!
Next Topic: Can I just sandbag it?
Current Time: Sun Nov 01 16:02:06 CST 2026
