Home » Sponsored » Pi Speakers » large woofers, small room, sound quality?
Re: which model of fostex's are you running?? [message #46597 is a reply to message #46595] Tue, 29 March 2005 09:13 Go to previous messageGo to previous message
Henry Eng is currently offline  Henry Eng
I have the older 208 sigma. Tried it in a back-loaded horn. Construction was too much for me, so I decided not to try a second BLH cab. Also put it into Martin King's MLTL but the baffle step circuit sucked the life out of the driver. I also put it on an open baffle and used a Behringer DEQ2496 to flatten the response and it was OK, but obviously no bass.
I've been thinking of a variation of the Dick Olsher Basszilla, by using an active crossover I can make a cheap bass-bin and use a small open-baffle with the 208 on top. Problem is cheap bass-bin may not match well for the dynamic and fast full-range driver. Costs and space are a concern otherwise I would get the same driver Olsher uses, an Eminence Magnum 15HO.
But if I spend that much money, I might as well buy a kit that has been well thought out so that I can get good results from the beginning. The 4Pi looks to be best bet, although the large 15-inch woofer has me concerned about how it will sound in small rooms of 12 x 12 or 15 and variations of that common to most houses.
Previous Topic: New power amp IC's as AudioExpress
Next Topic: Full range with seven pi corner horns?
Current Time: Mon Nov 23 07:04:01 CST 2026
