Home » Sponsored » Pi Speakers » large woofers, small room, sound quality?
Re: Many here use Pi speakers with 2A3 SETs [message #46591 is a reply to message #46590] Mon, 28 March 2005 12:22 Go to previous messageGo to previous message
Henry Eng is currently offline  Henry Eng
Do you feel that you have to sit farther away from the PI speakers than with other loudspeakers you may have used in the past?
How is the imaging? Palpability of voices?
It would be great if I can spin my turntables and mix techno at loud decibels, then at a moments notice lower the volume and change to some Dean Martin or Norah Jones, etc.
Thanks. I appreciate any comment you can provide.
-H-
Previous Topic: New power amp IC's as AudioExpress
Next Topic: Full range with seven pi corner horns?
Current Time: Fri Oct 09 07:07:18 CDT 2026
