There are a few things to consider. One is the area of the opening and volume of the chamber between the woofer and the walls. Another is the distance from the woofer to the wall. This is actually more important in this particular cabinet because the area of the opening is much larger than the area of the radiator. Then there is also the matter of height of the HF horns. So to keep things right, make sure the distance from woofer to corner is the same, the area of the opening is larger than 200in2 and make sure the MF and HF horns are approximately ear level within the dispersion angle.
