Home » Sponsored » Pi Speakers » Corner Horn Recommendations
Re: Corner Horn Recommendations [message #46373 is a reply to message #46360] Mon, 21 February 2005 05:49 Go to previous messageGo to previous message
I read Part 2 and Part 3 this weekend (Part 1 seemed only mildly relevant and the reference manual is BIG). Sounds like (no pun intended) there are definitely some issues to contend with.
having speakers placed directly into the corners doesn't give me a lot of flexibility when dealing with room resonance. Also, the fixed 45 degree angle of the corner horns doesn't leave much room for flexibility either.
What happens if opt for the 7's and build an asymmetrical horn? Basically, taking the existing design on rotating the bass enclosure a few degrees while leaving the corner section at 45 degrees.
This is starting to look like quite an engineering challenge.
Previous Topic: 2 Pi adjustments?
Next Topic: Great Plains Audio Club Meeting - March 19
Current Time: Thu Nov 05 18:16:03 CST 2026
