Home » Sponsored » Pi Speakers » The audio component I long for the most.
Re: The audio component I long for the most. [message #46322 is a reply to message #46305] Tue, 15 February 2005 07:07 Go to previous messageGo to previous message
Hello, I use A7 in a 14 x 17 room,so I know what you mean. I found a substantial improvement by toeing them in a little more than would normally be the case, with each stuck in a corner. This seems to not only improve the midrange, but imaging as well. If you weren't previously listening to "high efficiency" I also note a transition period of sorts when shifting between high efficency speakers and normal efficency speakers. If used to normal, high efficiency seem to sound as you describe, sort of head piercing on a way. Once tweeked and adjusted, (and you get used to them) normal speakers sound like close and play untill you readjust. good luck with all this. Hopefully soon you will get them setup and can start really enjoying them as they are a fine speaker. If you try the "extreme toein" I describe, be advised that small movements can shift the center image to one side or the other. soplay a bit.
Regards, russellc
Russellc
Previous Topic: Pi 4 w/ midhorn
Next Topic: Classic Studio 2 vs new Vifa Studio 2 - a comparison
Current Time: Mon Oct 19 16:26:45 CDT 2026
