Home » Sponsored » Pi Speakers » My One Pi's are done (almost)
Re: My One Pi's are done (almost) [message #46270 is a reply to message #46266] Mon, 07 February 2005 07:49 Go to previous messageGo to previous message
2 1/2" ports are hard to find. I custom made mine by cutting 2 1/2" holes with a holesaw through several sheets of plywood, stacking them together and glueing it behind the baffle.
Alternatively, you can expand the port to 3" diametre and lengthen accordingly. 3" plastic ports are very common and I can recommend a place in K-W for you.
BTW, is there a reason why the terminal cups are on the front baffle?
Gar.
Previous Topic: Pi components in Cornwall cabinet?
Next Topic: Altec 511B / 811B users? opinions?
Current Time: Sun Oct 04 16:43:49 CDT 2026
