Home » Sponsored » Pi Speakers » Professional Series 7 Pi Plan Request
Professional Series 7 Pi Plan Request [message #46150] Sat, 15 January 2005 15:01 Go to previous message
Jerrod Harden is currently offline  Jerrod Harden
Hi Wayne!
Could I please get a copy of the plans? I'll be running a pair of 2226's active below each midhorn and hf horn, but everything else should be close. I won't be needing to match a lf subsystem, so I can run the hf horn at the minimal 6 db attenuation which results in a 104 db hf section. I'm guessing I'll need to pad the midhorn down a db or two to get to matching levels. Do you know what resistor values would be required to attenuate 1-2 db in a 8 ohm system? I can convert for appropriate 16 ohm values. Thanks! Jerrod
Previous Topic: any one care to share their experience for the Pi 8?
Next Topic: Thermionic eight pi & Audiophile Seven pi plans
Current Time: Sat Nov 21 19:47:29 CST 2026
