Home » Sponsored » Pi Speakers » Crown Studio Reference amps
Re: Crown Studio Reference amps [message #46129 is a reply to message #46084] Sun, 09 January 2005 21:46 Go to previous messageGo to previous message
Kevin N. is currently offline  Kevin N.
With due respect, I come from the pro audio end of things. I listen with both my ears and eyes. By this I mean that both can be fooled. Inter conects CAN make a differance, how ever anything more then a 15$ cord does not. I will say that the TYPE of cable is - balanced vs unballanve , 75 ohm, shielded ect. is important, .. how ever 99.9% copper is not.
Amps. Most amps sound the same when operating at low levels - it is when you start to push them that they start to sound the way they sound. I have only "heard" the referance amps once, in the studio so I can't comment on them. However, I have found that crown's pro amps are very good, I have lots of use out of teh crown a 5000 ( 5000watt+ in bridge mono) running subs, and for a long time that was teh defact standard for touring. That is getting unseated a bit by QSC and the powerlight series though (PL 9.0 and 6.0 at 9000watts and 6000watts respectively).
What I can tell you for sure is that the amps are like the 1 bit that has teh LEAST impact on sound. - converts in teh CD player (and the clock they use) does make a differance, but the top 2 most imporant parts are room and speakers.
if I had to rate them-
45% - room
35-40% - speakers
7-10% - cd player - or record play - or 8 track......
5% - amp
.001 % - use of fancy cable sets
if you want to see wht you are hearing get a 40$ mic (ecm8000)and get teh demo for sia smarrt.
any way its late talk to you later.
Previous Topic: Building 2 pi Towers
Next Topic: WTB - JBL 2226J, 2123J pairs
Current Time: Thu Nov 05 19:21:27 CST 2026
